1 - 5 of 5 Posts
how in the hell does the heat work? i got it set to 90 degrees F but it seems to only be blowing cold air. i got it on auto fan hi is that right. does the defroster and rear defrost have to be on or something? ive read the manual but it doesnt say anything
ok the heat only works while im driving if im at a red light or the cars just idleing the air goes cold is that normal?
Check the coolant level.
(FREAK) :uh:
Also, check that the temp door isn't being effected by the vacuum/speed of the engine.
(FREAK) :uh:
its full
Check to see if your engine is getting up to full hot temperature. After driving for 15 minutes, grab the upper radiator hose, if too damn hot - OK. If not, I'd change out the thermostat with a 195 degree. If fuel economy is really bad, that's an indication it's not getting hot enough.
1 - 5 of 5 Posts
