1 - 20 of 25 Posts
i have a 1991 caprice that had sat for about 3 1/2 years. I did some work including cap & rotor, plug wires, o2 sensor, high flow cat, and the car still runs rich ive ran some sea foam through the gas as well.
any ideas....................shit is pissing me off :angry:
check maybe the TPS
Originally posted by Foompla+Sep 25 2006, 11:59 AM~6240001-->
you ahve any coolant in the car?
[/b]
Yes it is full
<!--QuoteBegin-blueouija
@Sep 25 2006, 01:57 PM~6240683
check maybe the TPS
thats one of the things im suspecting as well just have not checked it yet
Originally posted by Samuel_J@Sep 25 2006, 04:18 PM~6241517
Yes it is full
ALso Check your timing bro.... My 91 we couldn't figure out what was happening after we replaced the engine.... every time you were cruising along on the highway and romp the gas the car would suddenly run like ass and start doing 30 on the freeway... big loss of power.. the diagnostic tool said the car was running rich...
so after a huge several week long process of elimination my friend subscribes to a site for mechanics that has suggested fixes for all sorts of problems... come to find out tons of 91's have this problem.... and the fix was as simple as advancing the timing 8-10 degrees... It runs like a dream now and the diagnostic tool says the car is running lean
Very good thought. The cooling system is exactly what I would be looking at, more specifically the cooling temp sensor........
Very common problem on alot of Chevy's, the coolant temp sensor goes bad and reads the wrong temp thinking its colder and causing it to dump extra fuel to warm it up. The good news is the part is like 7 bucks and it screws into the intake manifold and is usually easy to get at.
For under 10 bucks I would just replace it and see how it acts. I had a 90 Chevy that ran real rich for years, I replaced that part and it fixed it right up.
a buddy of mine had an astro van that kept flooding out the motor! turns out the coolant sensor circuit was shorted to ground :cool:
:angry:
So i get a chance to work on the car today it was running so i buy a idle throttle postion sensor and idle air control valve and had to track a gasket set for the tbi and put everything together go to prime the system and gas sprays 3ft in front on the car from the tbi after disassembling the tbi one of the injector sleeves is missing a chunk i think this could have been the area that caused the car to run rich because it must have be a minor crack that was dripping adding gas to that side and it just gave out and broke during the removal and reinstall of the top of the tbi :angry:
luckly i have a another 91 to steal the top half of the tbi to see if the prob is solved this tbi :cheesy:
so i got the tbi back together and the car running but .......... fucking thing still runs rich!!!!!!!!!!! :angry: :angry:
anyone have any other ideas because untill i get the engine running right then i cant start on the fun stuff like redoing my setup and building my interior
HELP
HELP
try advancing the timing 8-10 degrees.....
is that where your timing is now?(8-10)
im at 8btdc and running rich, but i have a homeboy with a similar engine and says hes more advanced than me.... i was gonna bump the timing back a little and go from there...
I was at 10 and the original problem went away, BUT I found it was running like ass at idle so now we turned it back to 8 and it seems to be running decent at idle and the original problem hasn't came back. I'm going to keep backing the timing until I have a nice idle and the original problem dosn't come back , I hope
The funny thing is the books call for TDC on a 91 caprice but when you rep[lace a engine you end up advancing the timing....???? That dosn't make any sense to me but it works.
yeah, mine is at 8-10 now idling high, but the cam is 4* advanced, so i was wondering if i should be at 6=10
make sense?? lol
make sense?? lol
?? try bumping it back a hair
Originally posted by Foompla@Oct 15 2006, 04:45 PM~6372909
no
it doesnt work like that.
intial timing should be 6-10, total timing should be 28-32.  total timing matters, not initial as much
whoa, whoa, whoa there buddy.....
initial timing= "base timing", right ( idle, vacuum disconnected, etc)
total timing=vacuum connected, car accelerating/(not idling), right?
base timing is at idle. total timing is how high it goes when you rev it up.
cam timing doesnt have to do with your ignition timing.
1 - 20 of 25 Posts
