1 - 5 of 5 Posts
ok i check the fans useing jumper wires they work anybody know what could be wrong the ect on the water pump is new works fine the other engin coolant tep on the side of the block looks beat up not sure if it works and the water pump is new . anybody have a step by step guide how to fix it. when i turn the ac fan it does not work
unplug that sensor on the water pump and the fans should turn on. If they dont then its the fan relay(s) or fuse. The relays are next to the fuse box in the engine compartment, usually green. You can swap them with other relays to see if they are good or test them. Check all fuses that say fan too.
Discussion Starter · #3 · (Edited)
thanks for the help i found out what was wrong it was the plugin that is on top side of the fender wheel wall right befor it gets to the fusebox it was loose doesnt lock like tight need to buy a new fan harness anybody know where i can buy a new one cant find nothing on line
for the relay or fan? There are complete wiring kits but they are close to $100
1 - 5 of 5 Posts
