1 - 17 of 17 Posts
"Massive Power"
Massive Audio Pro Series amplifiers employ N – Channel circuitry which yields over 85% efficiency while allowing cool and stable operation even under the most challenging conditions. Each model features EZ Link circuitry allowing 2 Pro Series amps to easily link together as Master and Slave for upgrading and system flexibility. Additionally Each Pro Series Mono-Block has a Bass KomprerssorTM proprietary circuit for extreme low frequency output enabling your system to reach MASSIVE levels of Bass.
View Manual
Details
SKU SKUP15001
Weight 18.00 lbs
RMS Power 1500 x 1
PEAK Power 3000 x 1
[email protected] 950 x 1
Bridged RMS N/A
Min Impedance 1 Ohm
Min Impedance Bridged N/A
THD >1%
S/N 100dB
Max Voltage 15v
Max RCA Voltage 5v
Freq. Responce 8HZ-180HZ
Dimensions 17.5" x 8.7" x 2.6"
Bass Remote Optional
LIST PRICE: $449.95
Rockford Fosgate RFD2215 15" Punch HX2
* Two 3" 4 Layer LXtended Voice Coils
* Coil on Aluminum Former
* FIBERLock Cone
* Hyper XTended Pole Piece
* LXcursion Cast Frame
* Dual Laminated Progressive Flat Spider
* BART Surround
* CONsealer gasket hides mounting screws and provides an airtight seal
* Aeroport Exhaust
* Rubber Magnet Boot
* Dual 4 Ohm voice coils
* Frequency response 24-200 Hz
* RMS power handling: 600 watts RMS (250 watts per voice coil)
* peak power handling: 1200 watts
* Sensitivity 89 dB SPL
* Top mount depth 6-15/16"
* Sealed box volume 2.25-5.0 cubic feet
* Ported box volume 2.0-4.0 cubic feet
Originally posted by 87ls@Jan 11 2009, 02:26 PM~12670926
subs in sealed box with massive 1500.1 amp and group 31 battery $500
ummm i think price is posted :biggrin:
but if you cant see it, price is $500 obo
HOW MUCH FOR JUST THE SUBS
1 - 17 of 17 Posts
