1 - 20 of 32 Posts
What's up homies,
I'm pretty new to lowriding in general.. I have a 80 coude, that I'm planning to lift. What type of setup works best, or what have u encountered?? 2,3 or 4pump? I want to be able to have a high lock up and drive the car,do I need a slip? Drop mounts?
I appreciate any replies
im pretty new my self - and I just wanted to say that my car rides horrible with the rear end locked up.
maby its my crappy setup - but it might also be all that weight swingin around up in the back there - feels like the rear end is just steady fish tailin at any kind of good speed if the rear end is up past 3/4 way on some little ass 155/80 13s probly dont help much either.
maby some cars ride great at full lock tho.
mine dont n just wanted to toss that out there since it seem like you had wanted to mostly drive around up at full lock ?
I WOULD DO A 3 PUMP SET UP AND AT LEAST 8 BATTERYS RUN YOURSELF A PISTON AND AN ADEX TO THE FRONT AND 2 PUMPS TO THE REAR THATS JUST ME
YOU WANNA CLEAR THE GROUND ON 1 CLICK AND STILL PULL OF A COOL 3 WHEEL ...OR A 2 PUMP 4 DUMP STREET SET UP 4 OR 5 BATTERYS LAY N PLAY
I'm thinking of doing the 3 pump setup.. But not sure whats my best option
If you're just starting out i'd go with a simple 2 pump 4-6 battery setup. :dunno: Don't wanna break everything right away with too much power.
57 RAG
great advice he's a new guy to lowriding and other dude is talking about 3 pumps a piston and adex I"m like wtf
2 pumps 4 dumps is what you want starting out.. its easy to upgrade, and you wont have to get rid of any parts you dont need. maybe a few fittings.
SPELL CHECK
Originally posted by coupedup+Feb 2 2010, 09:52 PM~16493586-->
What's up homies,
[/b]
What kind of car? :dunno:
<!--QuoteBegin-MOSTHATED CC
@Feb 3 2010, 07:35 AM~16497422
:roflmao:
2 pump,6 batts would be nice for a lay-n-play for starters :cool:
Originally posted by 75HouseofGlass@Feb 9 2010, 03:21 AM~16556601
true shit i would work with a good two pump kit that you can upgrade as you grow into the sport
:yes:
I'm going to be installing my set up next week...I have 2 pumps and going to be doing 6 batteries. Is it easy to upgrade to 3 pumps if I wanted???
Phoenix Chapter President
4 pumps 3 adex's and 16 batteries......just for lay & play... :biggrin:
Discussion Starter #15
Ttt
EL Muertero
2 PUMP CHROME KIT</span>with choice of #8 or #10 re-designed Rockford gear,Choice of triple seal chrome cylinders (6's thru 12's) ; Deep front cup,coil-over rear cup and Pro "Magic Balls" ; #6 high pressure hoses with bite to wire fittings ; (4) chrome and polished dumps,w ith all chrome 3/8 fitting ; (4) or (6) Cole-Hersy switches
<img src=\'http://i243.photobucket.com/albums/ff281/BlackMagicHydraulics/2pumpstreetkitchrome-1.jpg\' border=\'0\' alt=\'user posted image\' />
Complete kit <span style=\'color:red\'>$925.00
check out the black magic 2010 tax time special ;)
this would be a good starter kit for you ;)
start simple you can upgrade at a later date 2pumps 4 dumps 6 batts will do for a start until you get an idea of what its all about and how it all works once ou get the idea then start to upgrade
x2
x2. That's what i'm starting with. :)
EL Muertero
[/b]
Originally posted by JOE(CAPRICE)[email protected] 11 2010, 07:34 AM~16581069
x2
<!--QuoteBegin-Switchblade
@Feb 11 2010, 11:38 AM~16583036
1 - 20 of 32 Posts
