1 - 15 of 15 Posts
Can anyone provide schematics? I need to know what the overall setup should look like plumb'd and wired including the pumps, dumps, solenoids, batteries, feeds, returns,...etc.....
Thanks in Advance.
L8
okay......I found these. I do have a couple of questions......
FRONT INSTALLATION.......
My 1st question is = The spring rests in the lower A-Arm pocker just like it currently is correct?????????? =
My second question is = Does the donut just slide over the cylinder all the way down and sit on the shoulder? If so, does the weight/pressure of the car hold the cylinders in place. That's what the donuts must be for correct???? The donuts must sit on the shoulder of the cylinder and press against the underside of the upper shock mount pocket???? =
Does the pressure/weight of the car keep the cylinders firmly in place? Do they have to be mounted or secured to the A-Arm or do they just "sit" in place????
1st question - Yes, it does.
2nd question - Yes, the donut will sit where the top of the spring once rested.
Yes, the weight of the car "holds" the cylinder in place. In some set-ups you have to be careful that your new 'shortened' spring doesn't fall out of place when there's NO weight on that corner; examples three-wheeling, hopping, hitting a big ass bump, etc. Depends on the car and the set-up though 'cause many lower control arms don't have enough travel to be able to move down far enough for a spring to fall out... but some do.
Originally posted by BOUNCIN89MERC2LOW97LHS+Jan 4 2004, 04:57 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (BOUNCIN89MERC2LOW97LHS @ Jan 4 2004, 04:57 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--1 LO 64@Jan 4 2004, 06:38 PM
Yes, the weight of the car "holds" the cylinder in place. In some set-ups you have to be careful that your new 'shortened' spring doesn't fall out of place when there's NO weight on that corner; examples three-wheeling, hopping, hitting a big ass bump, etc. Depends on the car and the set-up though 'cause many lower control arms don't have enough travel to be able to move down far enough for a spring to fall out... but some do.[/b][/quote]
Thanks a million........this is beginning to become more clearer now. Now.........
The Pro X kit I bought came with two different sized cups....ones deep and the other is about half the depth...which gets used in the front and which gets used in the rear??
Also......for installation on the rear......
I'll be doing a coil over (The diagram above show a coil under).......
Does anyone have pics of a coil over? how does the spring sit over the cylinder?
What gets welded where????
Does the cup get welded to the axle or the trailing arm? What holds the cylinder in the cup....a bolt? or does the weight once again hold them in place???
Car, truck... what?
The deep cup primarily just lessens the chance of a spring popping out.
If you're doing a coil-over, you won't be using cups because the spring will be coiled around the cylinder.
Originally posted by BOUNCIN89MERC2LOW97LHS+Jan 4 2004, 10:42 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (BOUNCIN89MERC2LOW97LHS @ Jan 4 2004, 10:42 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--1 LO 64@Jan 4 2004, 06:38 PM
Car, truck... what?
If you're doing a coil-over, you won't be using cups because the spring will be coiled around the cylinder.[/b][/quote]
Sorry.......64 impala..........
Also.........Coil under for the front.......should I do coil under or coil over for the rear????????
L8
Originally posted by 1 LO 64+Jan 4 2004, 07:12 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1 LO 64 @ Jan 4 2004, 07:12 PM)</td></tr><tr><td id='QUOTE'>
Does the cup get welded to the axle or the trailing arm? What holds the cylinder in the cup....a bolt? or does the weight once again hold them in place???[/b][/quote]
i had the same problem decidein on where 2 put my cylinders in the back either the rear end or the 4 link an i decided 2 put em on my 4 link but yo playa good luck on ya install i just now got everythang ready 2 put juice 2 it so ima got fuck wit my switches good luck keep us updated ;)
Originally posted by veto213+Jan 5 2004, 12:55 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (veto213 @ Jan 5 2004, 12:55 PM)</td></tr><tr><td id='QUOTE'>
i had the same problem decidein on where 2 put my cylinders in the back either the rear end or the 4 link an i decided 2 put em on my 4 link but yo playa good luck on ya install i just now got everythang ready 2 put juice 2 it so ima got fuck wit my switches good luck keep us updated ;)[/b][/quote]
Hey Veto.....you have pics or can you get pics of the rear end installation? Also, did you do a coil over?
L8
if your coil over -- you cut the top of the spring perch out to fit the cylinder thru.... give me a call later today ...BOB_T
Yea......I'll give you a ring!!!!
I have a couple more things to run past you!
L8
Originally posted by 1 LO 64+Jan 5 2004, 03:58 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1 LO 64 @ Jan 5 2004, 03:58 PM)</td></tr><tr><td id='QUOTE'>
L8[/b][/quote]
im doin a coil over on the back i dont got pics yet cause i cant find no 1 wit a good welder round here so all i got hooked up right now is the front
Discussion Starter · #14 ·
Originally posted by veto213+Jan 7 2004, 07:35 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (veto213 @ Jan 7 2004, 07:35 PM)</td></tr><tr><td id='QUOTE'>
L8
im doin a coil over on the back i dont got pics yet cause i cant find no 1 wit a good welder round here so all i got hooked up right now is the front[/b][/quote]
keep us posted, I would like to see your progress and install
L8 :cool:
Originally posted by 1 LO 64+Jan 7 2004, 10:13 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1 LO 64 @ Jan 7 2004, 10:13 PM)</td></tr><tr><td id='QUOTE'>
L8
L8 :cool:[/b][/quote]
1 - 15 of 15 Posts
