So i juiced my buick and I currently have 3 batts in it but seens like they drain kinda fast. Should i put 4 batts in and how should i run it? Lay and play no hoppin. 2 batts to each pump or 4 to the front and 3 to the rear?
Moderator
4 batts at a minimum for lay and play. 36V OR 24v to the rear, 48v to the nose.
charge while you ride - streetcharger.com
Thanks g’s also how many noids should i run? Rn i got two noids for the back on 36 volts and 2 to the front at 48v
