I have had this argument with others before. People tell me that they can do individual corners on a 2 pump 4 dump set up.
The fact is it is not possible, unless the car is raised all the way up.
With the car raised all the way up, then you can drop any corner and raise it back up because the other corner that is running off of the same pump is already raised up.
Dont believe what your homie is telling you. If he is so positive that he can do it, then go see his ride and let him show you. But just so you know it is not possible.
You could do it if you had a 4 dump manifold on each pump. But nobody with a 2 pump 4 dump setup can lift and lower just one corner.
If we could what would be the point of running a 4 pump setup? For looks or to take up more trunk space?
Also if you could control individual corners there would be no need for running 3 pumps or more when using a chain bridge. With just 2 dumps on a single pump running a chain bridge, you wouldnt be able to lift one side while you dump the other side because the fluid would just get pumped through the pumphead through the open dump and right back into the tank. The fluid takes the route of least resistance.
I hope this info will help you some, if you need more help just let us know. Also welcome to Lay it Low-Rob
