what sizeOriginally posted by Esoteric@Mar 5 2010, 08:07 PM~16807849
is there any advantage to having 3 subs as opposed to 2. the box is going to be ported and definitely going with FI BLs. what do you guys think?
12s but theres room for 2 15s, small blazer no rear seats. power? as in watts im looking for a 4000W ampOriginally posted by Airborne@Mar 5 2010, 10:08 PM~16810257
what size
BL's and how much space do you have to work with? What kind of power are you working with?
if u have the room do it as long as ur rms wattage is there who cares the load doesnt really matter with the ohm rise in a enclosure u should be fine...as long as ur close resting than u will b k...Originally posted by OUTHOPU@Mar 5 2010, 10:41 PM~16810007
If you have the room for a proper box for 3 and enough power it will be louder.
I would do 2 in a proper box at full rms power before doing 3 in too small a box with less than full rms power.
Ohms load doesn't usually work out great if your trying to run 3 off 1 amp though. Just make sure you sort that out first.
nah its not a true 4kOriginally posted by Pitbullx@Mar 7 2010, 04:42 PM~16821633
if you have a true 4kw amp go with a pair of fully loaded BTL's
what amp u got????..Originally posted by Esoteric@Mar 7 2010, 08:55 PM~16823020
Autotek mm4000.1d not the 1ohm stableOriginally posted by ROCKSOLID84@Mar 8 2010, 08:44 AM~16826832
if its the older one it should b close to 4k will run hot no matter how much reserve power u give it...Originally posted by Esoteric@Mar 8 2010, 06:12 PM~16830717
