OASIS AIR COMPRESSORS have been developed, tested and proven to be the fastest... most powerful 12v/24v DC Air Compressors available today. They are built to meet the most rugged requirements for service trucks and contractors. The hi-performance of these compressors is attributed to the use of 5 hp Prestolite™, winch type motors directly coupled to 10 ci, twin cylinder York compressors.
These models feature LOW VOLTAGE CUT-OFF PROTECTION which allows the compressors to output 200 psi @ 12vdc. Because low voltage, under high load, can damage a compressor motor, we have developed built in electronics with an indicator and automatic shut off that protects the motor.
Both HP1000™ and XD2000™ air compressors operate from 12v DC to 24v DC where they outperform the standard Shop air compressor. These heavy-duty compressors are ideal for field service work where time is money
THE HP1000 uses a 4.5”, 5 hp motor. Tests at 12v have shown outputs from 14 CFM @ 0 psi to 8 CFM at 100 psi, with a maximum pressure of 200 psi. At 24v DC performance dramatically increases up to 16 CFM @ 100 psi with a maximum pressure of 125 psi. The HPIOOO™ employs a unique high-output design that operates on standard vehicle electrical systems yet consumes no more power than other compressors for the same task.
While outperforming all others, the HPIOOO™ Air Compressor is compact - 17”L x 7”W x I0”H, weighs 45 lbs, and comes with 10’ of #4AWG power cable. The unit mounts almost anywhere on any vehicle and can even be used as a as a portable.
THE XD2000™ (EXTREME DUTY) version is designed for extended duty cycles. The “XD” utilizes a modified 5”, 5 hp motor with a cooling fan to dramatically extend the run-time by reducing heat buildup in the motor. Tests have shown a 90% duty cycle.
