Hey guys. I have a 2000 Lincoln Ls that we want to lay out on 22's. Question is I have not worked with Hydro's since 99 and have only built cars with air ride, mainly hot rods. I want a streetable system 1 pump with accumulators 1 was thinking.
Any Help is appreciated.
I have an air kit already for it but i'm getting bored of only using air and want to start building Lo Lo's again
Car is a 3.9L V8 Supercharged if that matters.
Thanks Guys
Tyson
YA ITS CHAPMAN AT THE FRONT, JUST BOLT ON THE 22S , THE JACK UP THE LOWER ARM TILL THE 22 HITS THE UPPER FENDER OR UPPER BALLJOINT MAXES OUT, THEN BUILD THE STRUT TO THE LENGTH FULLY COLLAPSED. SO YOU DONT LOOSE ANY CYLINDER LENGTH.
That is how I want mine to look just on 22's. Your stuff seems to be the go to right now. Could you put a kit together. How Much?
