If memory serves me correctly the 2000 Monte carlo you have to buy a long harness for and mount the factory radio in the trunk. The radio has to continue to be plugged in, even if you put in an aftermarket deck.
Thanks for the reply. After looking through the monte forums I believe that my factory amp is going out. Do you know if I can replace it with an aftermarket amp?
Sure you can. I am not sure, maybe someone else can chime in.....but you may need to purchase some sort of interface for the aftermarket amp to get it to replace the functionality of the stock one.....but shouldn't be too hard.
