1 - 10 of 10 Posts
Any one have pics or advice to getting my 13x7 reversed Daytons to fit. Calipers hit in front haven't tried the back yet just bought today. Is it doable?
1998 Lincoln Town Car
Curios, how much does a set cost ? I have a 1998 Lincoln...I'm hoping I do not run into that problem
If I get 90 spindles, is there any particular year and model, and would I use my brakes, caliber, and rotor ?
91-94 Lincoln Town Car front spindles. You will use the 91-94 rotors & calipers now and that’s what gives you the clearance.
Very much appreciated, I hope you don't mind me asking a few more important questions about my lincoln...When a frame wrap is done, is it impotant to plate the inside ?, and what brake system is used if I wanted to get rid of factory brake system, where that junction of hard lines are next to the cylinder ?
I used 94 Lincoln Town car spindles and calipers and you have to use your old brake line and you need to change out your lower ball joint with a 94 Lincoln ball joint so it fits the spindle better and new rotors and brakes for the 94 year also
much appreciated
1 - 10 of 10 Posts
