1 - 8 of 8 Posts
tops down bitch
looking to posobly buy 22'' reversed spokes for 2006 f-150..........and a freind wants them also for a 2004 H2,we want to know if they are a problem for vibrating ,we both own lo lo's and have had some small vibrations with 13'',and 14''..............so we want the 22'' to be reliable cause where we live we do alot of driving just to go chill witrh the homies or whatever....................nothig is really ever close so we want to be able to go on the freeway and do 75(miles),or 120(klm)
the only reason you get that vibration would be that your rims arent balanced and alligned. if the adapters are perfectally centered on the hub and alligned and balanced they are reliable as any other wheel
tops down bitch
true.......................i know someone who had 20'' standards and they vibrated since day one so i dont want that to happen to me and the guy with the H2..............also was wondering about the weight issue with the H2?..................
i dont think the hubs are big enough to fit the h2. that is 8 lug and the hub on wires barely clear my 6 lug chevy truck. lug holes on adapters actually run into the teeth. really close fit...
oh yeah, you will get a little vibration unless you run a bigger tire. i got 285/35 and that gives a shittier ride
tops down bitch
yea fuck...............i dont want no problems,i want to think and drive it like it's stock,cause you dont see too many reversed 22'' around..........and where i live in toronto can... usally there standards............my trucks black so i want black dish black hub,chrome nipples,spokes and hex k/o...............but we will see............ :uh:
tops down bitch
ya not too sure about that either..............gota get more info for both trucks :uh: :uh: :uh: i rally want some spokes..............every body has chrome 22'' and 24'' and up................but the 22'' reversed would look sick......
The Eater of Chicken
HERE IS THE WHEELS YOU NEED. AS FOR VIBRATIONS, I HAD A MACHINIST CUSTOM MAKE SPACERS THAT FITTED SNUG AROUND THE HUB. THE OUTERSIDE OF THE SPACER THAT CONTACTS THE ADAPTER WAS SHAPED TO FIT SNUG AGAINST THE CONTOURS OF THE ADAPTER. YOU COULD RUN THESE WHEELS AT 90 MPH WITHOUT THE VIBRATIONS.
http://www.layitlow.com/forums/index.php?showtopic=364879
1 - 8 of 8 Posts
