1 - 5 of 5 Posts
Anybody know where I can get some extended spindles cause the rim hits against ball joint
26's don't fit even with the correct offset and width, gotta lift it up. I just fit some 24 x 9" wheels with 255/35 24 tires and the only thing to make them fit was I had to grind off the studs that stuck out below the nut on both front upper ball joints.
1 - 5 of 5 Posts
