1 - 9 of 9 Posts
Right now ive got 3/8 port valves running half inch lines. I read on most websites where it shows the 3/8 valves and it says for use with 1/2 lines. I was wondering if i bought 1/2 port valves if it would improve the speed by a lot?
I Dig Chix Wit Glasses!!!
prolly not. You might not even notice the difference
IT IS NOT THE VALVE WELL NOT REALLY BUT HELPS THE MAIN THING IS THE ???? WELL IF I TOLD U ILL BE OUT OF WORK MIGHTEST WELL CLOSE MY SHOP.. :biggrin:
just think about it a valve is about 2" long and the line is alot longer i dont think that 2" will decrease anything by much its cool to say you have bigger valves tho becaues bigger is better except for rims
WELL SEE THE VALVE WORKS LIKE A FLOW IF THE FLOW IS ONLY 1/4 OF THE ACTUAL INLET HOW MUCH PRESSURE YOU ARE LOOSING
NOW IF THE FLOW SAME OR BIGGER THAT INLET HOW MUCH MORE FLOW DOES IT HAVE :cool:
1 - 9 of 9 Posts
