1 - 20 of 23 Posts
got a 3 dump setup for three wheel on back pump i can raise whole ass butt when i raise one corner to pose wont cum up motor barley spins other corner cool motor spins normal back switch normal just one corner dont work real good do u guys think it the dump or switch or a noid !!!
if the pump sounds like its struggling, try swapping the motors for the pump that does work....you might have a bad motor
motor spind good when hit back switch just when raise left corner to pose
and its just 1 pump with 3 dumps?
one pump for ass with three dumps
ide check the switch are you using 3 6 prong switches?
SO FRESH!!!!!
why 3 dumps ?
yea, IF both sides raise up fine together but the one corner doesnt on its own its probably a switch. Could be solenoids depending on how you did them, two banks or one and how you wired it if your using one.
actually, studying your pic, your blocker dumps have to open to get fluid to the cylinder, then they have to open again along with your releasing dump to dump the fluid. Yea that would be interesting to see how you wired that... Theres ALOT of ways to screw up the wiring with the switches or solenoids since you have the same wires hooked up as dumping and powering the pumps and opening the blockers.
Discussion Starter #11
one bank of 9 shit was cool for a month or two than just fukd up that one side wont dump and when i hit it up one side motor dont really spin got 3 prong on the switch
Phoenix Chapter President
Originally posted by sp00kyi3@Jul 6 2009, 04:57 PM~14395737
That shit is genius.......Im gonna try that on my rear pump.You learn something every day. :thumbsup: are you using a 6 prong switch for each rear corner?
Discussion Starter #13
mite be 2 irun 4 to back and 9 to front so guess its 2
Hell yea this is what i have been wanting to do until I get a 3rd pump,, Is the cutty in you avatar on 3 wheel with that 3 dump setup?
Discussion Starter #15
yea thats her on three it goes up both wayz pretty good
Discussion Starter #16
had to double check got nine bateries runnin 96 volts fisrt two wired in parrell last 7 wired series power to back solenoids cums of 5 battery to 3 solenoids to back pump 6 prong carlings runnin think it switch it dumps just dont cum up rite gonna get a new switch and go from there
So you ever get your problm fixed homie? I want to see more single pump 3 and 4
dump setups!
Discussion Starter #18
dump setups!
yea fukin switch
Wait,, how you getting both sides to power 3 with only 3 dumps? Ya'll got me all confused.
1 - 20 of 23 Posts
