1 - 20 of 23 Posts
I got a 2 pump setup with 8 batteries in my 86 Cutty and im willing to stand a three without having a 3rd pump.. i heard attaching 4 more dumps to the rear pump would make it three.. but would i need something else in addition to make it stand on three just so if 4 dumps dont work out?
lock the car up and dump the back corner, if it doesn't three then adding more dumps to you pump won't help you. that is only done so that you can lift individual corners without adding another pump. you would have to do a chain bridge in order for that to work. :cool:
i got 10 batteries and coilover in my regal and it stands 3 it wouldnt do it with 8 so try adding two more batteries. i would show pics but dont know how
:biggrin: IM DOIN IT WITH 8 BATTz ON MY FLEETWOOD
How?
What size cylinders are you running in back?
Ive seen plenty of rides three-wheel with 2 pumps...all u need is a coil-over setup, long enough cylinders, and make sure u have enough weight at the rear corners...
:c : :
YUP I GOT MY SUBS GIVIN WEIGHT TO DA CORNERS :biggrin: RESNTLY JUST GOT MY PUMPS LIKE 4 DAYS AGO :cool:
I am running 10s in the back from the basic kit of Pro Hopper
Everything in my car is pro hopper.. according to the weights i got my 8 batteries lined up in the end of the trunk and pumps towards the Cylinders.. plus i got pro hopper adjustables upper trailing arms
HI-LOW :puffin:
INSTALLD BY HOLLYWOOD CUSTOMz
Discussion Starter · #14 ·
I love Hi-Lows and Black Magic :cool:
:puffin: :thumbsup:
to be able to do that you have to have longer cylinder's i would say 14's and add more weight to the rack or more batts .
ya u aint gunna get shit wit 10's unless u lay frame layed out then maybe a couple inches
Phoenix Chapter President
12" CYLINDERS AND COIL OVERS WITH DEEP CUPS........
SELL 0UT
Problem Solved :biggrin:
1 - 20 of 23 Posts
