1 - 12 of 12 Posts
finished installing a 3 pump setup 2 to the rear showtime,piston to the nose and wont do a standing 3 have a 3 1/2tons full stacks rear has 10in cylinders precut 2 tons sits pretty high have the rear shackles but rides rough with um on so took um off any help.
what kinda car? You need at least 12s in the rear to put it up on three
97 chevy s-10 excab
yea I had a juiced s10 too, how are the rear cylinders mounted - on the leafs or the axel?
if it's a leaf spring setup it won't 3 on 10's or maybe even bigger unless you have a bridge.or a shit load of weight.it's sometimes hard to 3 on leafs because they bend when you 3.with alot of coil in the back plus them cylinders,just becarful not to brake the leaf spring.i've seen that happen.if your going for 3 wheel.go to auto zone and get you some leaf spring extenders and that will relieve some stress and 3 wheel alot better and even lock up higher.
ya youd wired it up just using 10 batteries thats all. nothing special, 24v same thing, whatever voltage u want to run ur back pumps 36v or 48 same thing, then 10 batteries to the nose, unless ur running 2 banks of batteries.
has a bridge runnin 8 batts got those extenders 4 the leaf spring but rides different when on gonna 3 link it over winter while she is parked but not just yet
will the full stack make a difference, down all the way but looks like its locked up
The Great White Hype
yeah I can get a rollin 3 with 12"s but I dont think I could get it with 10"s
Discussion Starter #12
midland tx. :cool:
1 - 12 of 12 Posts
