1 - 5 of 5 Posts
True-S Mike
well you will have to re wire your switches UNLESS there wired up and ready for that. ( pre wired's useally are for 4 pumps )
are the 2 pumps workin off of 36 volts each now? if so, if you put the second pump for the rear then you the set of batteries that work the front ( and so on ) there should be a difference.
if there wired in a series ( 72 volts ) thats a differnt story. if you have 2 pumps gettin power from the same battery it will over work it or strain it.
i notices from going 2 pump front at 72 rear at 48 to front at 72 2 rears at 48 my batts drain alot faster
1 - 5 of 5 Posts
