1 - 20 of 39 Posts
Ok so what do I use to run 3 pumps to the front? Y Block, X Block, Im tryin to figure it out :confused: Any hoppers out there?
SELL 0UT
2 y BLOCKS AND 1 x BLOCK..
Never seen it done.. Might Be Pretty Neat To See...
Just My .02
Cylinder Cylinder
X
Y Y
Pump 1 Pump 2 Pump 3
I agree with what supreme said. 3 is just a waste. If your looking for power 2 to the nose is more than enough with the right combination of gears & volts. Just make sure the rest of the car is also built right.
57 RAG
my brother has 6 pumps in his cutlass 3 to the front and 3 to the rear so it's like a pump n a half to each wheel. I'm trying to talk him into changing it into a 4 pumper though
Banned
the most anyone really needs is 4 pumps, anymore is just retarded
but how do you get equal presure from 3 pumps to 2 cylinders, any pics of his set up? Im runnin 2 #11 gears at 96v and want to add another :biggrin: Cause Im PSYCHO :puffin:
Originally posted by MOSTHATED CC@Sep 30 2007, 11:46 PM~8904164
it has 2 pumps with one dump and one pump with 2 dumps and two y blocks does that make sense..
:uh: woa, Im too twisted rite now to understand that shit. Ill check back tomorrow ;)
Originally posted by MOSTHATED CC@Sep 30 2007, 10:41 PM~8904113
the joker had 6 pumps and jerry lam use to have 6 pumps I believe
but used as back up pumps to keep it dancing whe motors burn out.
57 RAG
are you sure about that because thats not what he explained to us at a show a long time ago?
2 pistons to the nose should be all you need, if you cant work with that.......................................................................................never mind.
only way to do it with same ``pressure`` but alot of fittings :0 :cheesy:
bad photoshop :biggrin:
or get a manifold done 3 into 1 etc etc ;)
:biggrin: :biggrin: :biggrin:
1 - 20 of 39 Posts
