1 - 20 of 31 Posts
I am having a hard time getting my car to stand-still 3 wheel. I have 14"
cylinders, bridge and upper drop mounts. When i drop the corner the shit barley drops. I can barley get it to hit a 3 wheel in motion! Any comments? Ill post pics today
not enought weight over hanging the corner to lift the motor up if you have a bridge you will have to run chains and 3 pumps to get it to sit on 3
if it wont just fall over then theres not enough weight what cars it in 1st off will it do a rolling 3
Originally posted by ostrichcutty@Jan 19 2010, 12:27 PM~16338962
ive tried that and no luck.
The upper drop mounts are what's stopping the car from standing 3. You changed the point of where the arm pulls down on a corner.
"LESSON LEARNED"
x2!!
lock up all four, dump the right side, then lift the back again to get more out of the left cylinder, then lift the front again.
What kind of trailing arms do you have?
the way i do it dump the back lock the front up and just hit the switch on a rear corner i got 3 pumps 2 in the back and one to the front :)
thats the way it works, however he dropped his upper trailing arm mounts to a lower position, which unless he uses chains to chain off how high the rear locks up before it pulls down on the corner to make it stand 3 its not going to, cuz he has changed the pivot point of when the trailing arm pulls on the car
x3-drop mounts fuck up a 3 wheel-drop mounts are better left to drivable "hoppers" with slip yokes :yessad:
Discussion Starter #17
I have stocks for now bcuz I'm waiting for my driveshaft
Originally posted by ostrichcutty@Jan 20 2010, 12:12 AM~16347809
They are old compressed from a hopper
i told u what ur problem is as well as another guy..its not the coils...its the drop mounts, cuz most people drop the mounts around 4 or more inches..my car has 16s in the rear with drop mounts and i can lock up one corner and the whole rear end lifts up and it wont stand 3 wheel until i push down on the corner..
if ur drop mounts are bolt ins, remove them and put ur arms back to the factory spot...then try to stand the car up...i bet it will
Originally posted by DOUGHBOY1117+Jan 19 2010, 05:10 PM~16341952-->
x2!!
[/b]
<!--QuoteBegin-danp68
@Jan 19 2010, 10:50 PM~16346464
you can lead the horse to water, but u cant make em drink...although youd like to drown em lol...
1 - 20 of 31 Posts
