1 - 20 of 49 Posts
right now i have a 350 transmission in one of my rides,i know it will probaly go out soon cause i just got the motor redone,
now my question is wich trans do u recommend for a motor with a little extra horse power. should i rebuild the 350 or get a 400 trans?
i do plan to haul soem ass,smoke some rubber and cruise .
any info will help.
SPELL CHECK
Stick with the TH350, for several reasons. They're excellent transmissions, and you can build them to suit just about any horsepower level. They're lighter than a TH400, and rob less power, so ultimately you'll get better gas mileage. Also, you already know it will bold right up, so you won't have to change your driveshaft. ;)
Cheers,
Jeff
:biggrin: THAT IS TRUE A TH350 IS BETTER THAN A TH400 AND IF YOU GET IT BUILT RIGHT IT SHOULD LAST A LONG TIME
400 is better,,and you know you dont need to worry about driveshaft
i was reading that a 350 and a 400 are about the same thing but the 400 is more towing and heavyduty and a 350 is more for racing
Here are some common tranmission gear ratios:
Transmission
Model First Second Third Fourth Reverse
Rear Wheel Drive:
TH-180C (3L30) 2.400 1.479 1.000 --- 2.000
TH-200-4R 2.741 1.568 1.000 0.674 2.067
TH-300 (Jetaway)
TH-350 2.52 1.52 1.00 ---
TH-400 (3L80) 2.482 1.482 1.000 --- 2.077
TH-700-R4 (4L60) 3.059 1.625 1.000 0.696 2.294
4L30-E 2.400 1.479 1.000 0.723 2.000
4L30-E Optional 2.860 1.620 1.000 0.723 2.000
4L60-E 3.059 1.625 1.000 0.696 2.294
4L80-E 2.482 1.482 1.000 0.750 2.077
1) the 350 weighs less.
2) the 350 has a slightly lower first gear (2.52 vs 2.48).
3) and finally the supposed HP loss difference.
or click here http://www.442.com/oldsfaq/oftrn.htm#TRAN%...on%20Comparison
th400s have the advantage for big blocks/big cars but a th350 can be built strong enough for basically anything... unless youre building a drag strip car with 600 + ft/lbs of torque
Plus 400s do take less power to run
any info will help.
go with the 400 if you have the money!! what car is it for? if its for that big ass chevy you bought i would go with the 400 thats a heavy ass car and 400 would work better for you especially if your thinking of filling the trunk with batteries :biggrin: !
Just got my car from the tranny shop, stock 327 with TH400 from factory. Man this car hauls ass........
I have not driven an old school V8 in a long time.....boy it's nice to be back....
The car is a 1968 Impala Fastback........mech said it was probly special order with the TH400.....
Discussion Starter · #19 ·
sounds cool,thanks for the pointers,i will most likely go with the 400 trans after i wear out my 350 trans.
from what i hear it sounds like the right way to go, but again the 350 with a shift kit sounds cool,but i would have to re do my rear end before i go that route.
i'll run the 350 till it goes out.
1 - 20 of 49 Posts
