1 - 12 of 12 Posts
i was thinking 4 batts... but not sure on life of batteries..
who runs 4 batts in the streets? i like to play a bit at stoplights..
am i better with 6 batts?
not tryin to do anything special, just simple front back setup for now..
Phoenix Chapter President
I switched from a straight 72v to running 48v with 6 batts,i can lay and play all day long!!.....
so youre runnin 6 batts wired 2 in parrellel? i was thinkin of that.. longer battery life... and hopefully could make it through the weekend no charge
yup,4 batts with 2 reserves but Im running a street charger so they are always charged :)
My last car had 2 pumps,6 batts, 36v to each pump, worked great, batts seemed to last forever, i didn't daily drive it tho.
im on 4 batterys right now with a little 2 pump setup.
running 48v to the front and 36v to the rear
just replaced all 4 batterys with fresh dekas and I bet I could ride all weekend with my setup hittin it some....
but I dont like the idea of not charging the batterys up after a hard days use - just to make shure they always maintain a high level of charge should help them last a long time.
I do plan to add 2 reserve batterys on my car tho to have 6 in total
but I need to re do my rack and pump mounts for the extra batts - as mine now can only hold 4 batts wich sucks
I say build your rack to hold 6 batterys - and if you only use 4 then great but you have room in the rack to hold more if you decide to use them later on. thats whats catchin me up right now.
Originally posted by brian84corvette@Mar 4 2010, 06:56 PM~16798050
deep cycle batteries were engineered to discharge and recharge, repeatedly
i only got 4 in the 5th homie, n i get plenty of use out of em
im runnin 4 in mine and havent charged em in 2 weeks. 48 front and 24 back. works good for me. had 6 but 2 crapped out this winter
1 - 12 of 12 Posts
