I have 4 pumps but only want to run 4 batteries 2 to the rear and 4 to front can someone make me a wiring diagram for help...
Originally posted by 4PUMPEDMONTE@Nov 22 2008, 06:00 AM~12228272
Ok now I am really confused you have split bank 10 battery setup in the diagram
I only want to run 4 total batteries
one ground
2 of those batteries I want to run to the rear 2 pumps but I want all 4 of the total batteries I have to run run the front two pumps
Also where does the switch to wire from the switch go? On which battery...
King thanks for the help but it really confused me
Originally posted by 4PUMPEDMONTE@Nov 23 2008, 03:03 AM~12234211
So should I just run all 4 to all 4 pumps I know it will die quick its just on my daily really just to play around with nothing big dont even want it to be really fast
x2. 4 batts will only last lifting the car maybe 10 times. unless you lift then leave it up all day youll be charging every night. if you dont want to be quick. go down to 2 pumps. with 4 batts. not real quick on 48v.Originally posted by KINGFISH_CUSTOMS@Nov 23 2008, 01:24 PM~12235071
if ur not lookin to be fast. then i would do 6 batteries and wire 3 of the batteries in parallel to make 12v and wire the other 3 batteries in series. that will still give you 48v to the front and rear, and youll have good reserve from the parallel. im not tryin to steer you from what you want, but i dont think youd be happy with the results of 4 pumps and 4 batteries and constantly charging them up.... and worse would be you stick some solenoids cuz ur batteries were to low....
sure homie. i can do that.Originally posted by 4PUMPEDMONTE@Nov 23 2008, 02:38 PM~12236015
Ok can u draw me something up to show me I will go with that then
