Originally posted by sixduecechevy@Sep 4 2005, 09:19 PM~3751915
the amp has a power and ground wire, but also has 9 wires that are grouped. It has a place for rca's rea and front that is labeled inputs. I guess my question is, did older have use wire instead of terminals.
Yes, old Orion amps have wire pigtails instead of screw terminals everyone is so spoiled to...
You will have your power and ground wires sticking out, then 9 wires on another plug sticking out, UNLESS it's a common ground amp, then you would have less wires...
If you have the 9 wires, 8 are the 4 speaker channels and ONE wire is the remote turn on lead...
