1 - 20 of 59 Posts
Does anyone have a wiring diagram for a 4 motor 4 switch setup, I tried searching but it says something about it being disabled
im working on my first hopper and its a 4 motor/4 switch setup. mines a Hoppin' Hydros kit so its already prewired.
but it should be pretty simple to do.
it should have one wire from each motor all running together for the negative side and then the other wires going into each switch (one wire/motor per switch) then power going to the other side of the switches.
hope this helps some?
what 1OK posted would be independent (whatever way u spell it). 1 switch for each motor. and also you would be able to make the motors go back and forth.........this is what i have on my 63 hopper.
Mad are you talking about 1 switch for back, one for front. and 2 switchs for s 2 s?
I saved both of your diagrams, ;) I know that they will be very helpful later on. Thanks guys :biggrin:
1 - 20 of 59 Posts
