1 - 20 of 56 Posts
i installed a 4 pump 10 batt. setup in my 76 caprice. 14s in the back. 10 batt are straight across the back.60v to the front 36 to the back. the car will not roll 3 or stand 3. i still have the rear sway bar on. will that fuck it up?
i have tried lifting 1 rear stroke at a time.
i have tried bringing the rear up and dumping the appropriate side.
i have tried both of those rolling and stopped.
let me know what to try next. i have never seen or heard of before.
Personally, I would start by replacing the rear axle and taking off the sway bar... that's exactly what the sway bar does, it stops independent side to side movement of the rear end, it helps reduce body roll... next, is your frame completely wrapped??? If not, that is VERY important to the life of your car to have a strong frame, especially with 4 pumps and 10 batteries, not to mention the twisting the frame goes through when trying to 3 wheel...
aint gonna do shit with that sway bar on.....take it off...only takes a few minutes to pop those couple bolts off
clean car from what i can see btw
TURN THE WHEEL BEFORE U PRESS TEH GAS DUMP THE CORNER AND HIT THE GAS DAT TIPPS MY CAR OVER ON 3 IN A HEART BEAT HITS THE BUMPER
remove the sway bar homie
even with reinforcing frame you better fiberglass the shit (my bad) outta those 1/4 panels ... those body caprice ,impala's have a tendancy to buckle .. past the tire well
if you dont know, now ya know!
Member # 1,077
YOU NEED AT LEAST 48 VOLTS TO LIFT A 3 WHEEL. ANY LESS ISNT ENOUGH JUICE. TRUST ME.
Member # 1,077
oh and the sway bar is countering the 3 wheel, take that bitch off. i dont have one and it dont seem much differnt to me
LAYEDBACK
My car pops right up in three on 36 volts. :dunno:
OHHH And loose the sway bar...... :biggrin:
Member # 1,077
you can make an impala 3 wheel easy with anything :biggrin:
LAYEDBACK
True.....true.... :biggrin: :biggrin:
my g body has had 36 v to the rear forever and it stand 3 all day 48v is to fast for mee on the back
Member # 1,077
does it have a v6? :uh:
Discussion Starter · #20 ·
no it has a 350 and i put a bridge in from spring tower to tower made of 2.5 x 2.5 under a 6" x .25 plate, but never put on the chains.
1 - 20 of 56 Posts
