just got it bak from da shop... and he said sumthing bout my cylinder not puttin anuff preasure or sumthing and makin it push out more gasoline den needed?.... wha happens wit da car is it has no power at all...i press da gas and its lik no real power... and ok if i press da gas a lil bit it sounds loud but doesnt move much, if i press it more it quitdowns and doesnt move any faster and if i press it more it gets loud again and den moves a lil faster.
so i checked da book i have and dis is da shit it can be :
1. incorrect ignition timing
2. excessive play in distrutor shaft/also check 4 worn rotors,faulty dis. cap,wires,etc.
3. faulty/incorrectly gapped spark plugs
4. fuel injection unit not adjusted properly/worn
5. faulty coil
6. brakes binding
7. automatic transmission fluid level incorrect
8. fuel filter clogged/impurities n fuel system
9. emissions control system not functioning properly
10. use of substandard fuel
11. low or even cylinder compression pressures.test wit compression tester which will detect leakin valves and/or blown head gasket
k now i know its not 1 cuz he just did da timing, 2..maybe cuz it was loose but he fixed dat but he did say i needed new rotors and my one of my posts on da dis. cap is kinda broken..3...maybe cuz i just changed dem and i dont kno wtf gapped means but dis prob was even b4 i changed da spark plugs...4...maybe...5...maybe....6...maybe i do need 2 fix da brakes...7...maybe...8...maybe and i just got a new fuel filter but havent put it on....9...maybe...10...no cuz i only put 93 octane....and 11....is kinda wha he said it was...
i dont kno wur 2 go from hea... i brought da car bak home and i dont kno if i should look 4 another engine or wha
need a lil advice
83 coupe deville 4100 engine
5. faulty coil
6. brakes binding
need a lil advice
