1 - 11 of 11 Posts
how hard is it to get parts for these engines?
also if theres a rocker loose do i have 2 just adjust them or buy a new rocker?
any tips about these engines would be apprieciated thanks
You should be able to adjust them... DAYUM good engines!!! :thumbsup:
well the thing is a rocker is loose and im not sure if i need new rockers or i can just adjust them...
thanks for your guys replys
try a higher octane fuel. Sometimes pinging may sound like lifter knock. change your oil with some of that enigine flush. you may have a sticking lifter. if not you have broken or damaged spring or cam
try a higher octane fuel. Sometimes pinging may sound like lifter knock. change your oil with some of that enigine flush. you may have a sticking lifter. if not you have broken or damaged spring or cam. check hereforums.500cid.com/
1 - 11 of 11 Posts
