can u put a 350 in a 1988 cadillac that has a 5.0 engine in it and it will bolt rite in without major modification
some caddies had olds 5.0 on them until 90Originally posted by Swingin80Lincoln@Aug 30 2005, 05:50 PM~3721758
gm makes 2 different 5.0 engines. one is a chevy 305 which is interchangeable with a 350, 327, 283, 307, 383 or 400.
the other is an oldsmobile 307, an olds 350 rocket will drop right in, but i dont think you are talking about that engine.
chevy has its own bellhousing pattern and buick, olds, pontiac, and caddilac share another. some transmissions like the 2004r have both patterns.
so to swap a chevy 350 in place of an olds 5.0 (307) you will need the engine, frame motor mount brackets, and transmission. the exhaust will also be different. depending on the model of trans, you may also need another driveshaft or have yours shortend.
what does the intake say?
if it says oldsmobile on it its an oldsmobile
post pics and well tell you
Just swap to a olds 350 rocket homieOriginally posted by TWisM85CUT@Sep 2 2005, 09:36 PM~3743790
This is actually the same thing I am going through right now. I am trying to swap my Olds 307 to a Chevy 350, But there is so much stuff that has got to be changed it is horrible. :thumbsdown:
