1 - 20 of 33 Posts
Any good suppliers 5/8" Lines and fittings.
whos got best prices?? :biggrin:
Face Puncher
maybe he plans to run some 13/16 valves and 21/32 ported bags...
i wanna know what his whole set is like since he is using suck big valves then i wanna know what pther tweeks he's doing to his car
Simple enough.
DOT Air Brake line is measured O.D. (outside diameter)
So 5/8" O.D. airline is truly 1/2" ID
5/8" OD = 1/2" ID
1/2" OD = 3/8" ID
3/8" OD = 1/4" ID
Having 1/2" valves with 1/2" line is ineffecient. To get full potential from a 1/2" valve you need 5/8" Airline when going DOT.
I was running 1/2" Parker Gold Valves (5/8" orifice) and 3/4" line getting all 4 airborne on one hit at 200psi.
Check the yellow pages in town. Look for a place that does work on Semi Trucks. They should have some DOT Air Brake line for sale.
Face Puncher
hmmmmmmmmmmm.. never heard that before..
I bought 1/2" DOT line and 1/2" prestomatic DOT fittings..
my tubing is .500 OD, .375ID, .062 wall
rated to 200 psi
Are you sure your using DOT Nylon AirBrake line?
Because I have 100 foot roll each of 3/8", 1/2", and 3/4" I could Mic at the shop tomorow. It IS measured OD in the books.
Face Puncher
as long as I've been doing shit with air and oil lines, the rule has always been..
tubing is sized by OD
hose is sized by ID
lets say I were running non DOT line...(which I am)
if I bought DOT fittings, and the line fit, what does that teach us?
well i just ordered my 1/2" valves, and im lookin for 5/8" air line... if anyone knows where to get some airline and fittings, pm me please!
Discussion Starter · #13 ·
Why the fuck is 216 running 1/2" valves with 1/2" od Lines?
That shits backwards!!!!
U are still limited at 1/2" to 5/8" fitting.. but thats not worth noting.
but if you then drop to 1/2" line like 216..might just as well run 3/8 valves...
air rating on the valves could be it
Discussion Starter · #18 ·
Please correct me if i am wrong but 1/2" NPT does not measure 1/2".................
It is larger than 1/2".......... more like 5/8" on a ruler......
Face Puncher
Originally posted by Navi@Nov 3 2003, 12:18 AM
and DOT Nylon AirBrake line is considered Tubing.......
Which tubing is measured OD.
Need proof?
http://www.parker.com/brassprod/cat/3501e.pdf
my point exactly
thats why 1/2" DOT line is 1/2" OD, not 5/8 like you said...
or at least I think you said
so many numbers I forgot now... :biggrin:
Face Puncher
parker prestomatic fittings..
5/8" tube by 1/2" NPT straight..........p/n 68PMT-10-8
same sizes swivel 90°.........p/n 169PMT-10-8
anyplace that carries parker shit should be able to get your hose and fittings for you..
1 - 20 of 33 Posts
