i have a blazer that i want low but i also want air ride so do you have to lower it first or when you get the bags well it sit low heres a pic of it
depending on how large of a wheel he goes with will tell is spindles are needed to lay crossmember.Originally posted by serge40t@Jul 25 2005, 04:43 PM
You are going to need drop spindles if you want to lay the front out. For the rear, you'll need a three or four link set up ( I would suggest a four link). If you decide to just keep the leaf springs and do an over leaf setup, you'll need a mono leaf.
To answer you question, no you don't need to lower it first. Putting a four link on a blazer is a bitch because you'll need to cut out the floor in the back you might lose your back seat depending on the size of the notch you put in. The front is easy...all you have to do is remove the springs, trim the spring pockets and put in your bags and brackets and drop spindles.
I'm assuming your truck is a 2wd, correct?
Here is a blazer I just sold. I would have loved to bag it.
[snapback]3476441[/snapback]
he's using 13's.Originally posted by Mark@Jul 25 2005, 03:54 PM
[snapback]3476527[/snapback]
now that looks TITS!!!! :thumbsup:Originally posted by serge40t@Jul 25 2005, 03:43 PM
i lay crossmember with out spindlesOriginally posted by aleigh-n@Jul 25 2005, 06:31 PM
he's using 13's.
[snapback]3477343[/snapback]
