1 - 13 of 13 Posts
I was readin the forum on the different pump #'s and I still don't know the difference. What # is most common? What # would be best for hoppin? And what # would be best for your normal rider?
Also, is it best to match the hose # with the pump # for best results?
Originally posted by NoUse@Nov 4 2003, 01:10 PM
i have #11's turning in my front pump, running at 60 volts, #8 hoses.. 3.5ton springs.. Im happy with the preformance, but could I run more voltage, or should I change my gearing??
how high is that gettign you?
Originally posted by IhopMY95+Nov 5 2003, 12:24 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (IhopMY95 @ Nov 5 2003, 12:24 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--lowridincalivato@Nov 5 2003, 04:17 PM
#6 =  low volume, high pressure.
#13 = higher volume, lower pressure.
even #'s are regular steel pump heads
odd #'s are italian style alloy type head.
so what would you recommend?? steel or italian alloy??[/b][/quote]
I prefer, and recommend the italian gears... much better performance.
1 - 13 of 13 Posts
