1 - 13 of 13 Posts
Has anyone here used 6v motors before? It seems like a good idea, because you can use half of the batt's. But, do they burn out quicker?
Originally posted by S10lifted@Oct 13 2003, 07:21 AM
If I'm not mistaken they don't have very much torque.
IF YOU RUN 4 BATTERIES TO THEM, THEY WILL HAVE TWICE THE TORQUE AS A 12 VOLT MOTOR WITH 48 VOLTS.
Originally posted by S10lifted@Oct 13 2003, 09:34 AM
So why are they bad for hopping?
THEY BURN UP QUICKER. THEY ARE 6 VOLT, AND HAVE 1/2 THE NUMBER OF ARMATURE WINDINGS, WHICH WILL EITHER BURN UP OR THE WIRE WILL SLING OFF AT HIGH RPM'S.
Originally posted by ogcaddy+Oct 13 2003, 08:12 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (ogcaddy @ Oct 13 2003, 08:12 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--S10lifted@Oct 13 2003, 07:21 AM
IF YOU RUN 4 BATTERIES TO THEM, THEY WILL HAVE TWICE THE TORQUE AS A 12 VOLT MOTOR WITH 48 VOLTS.[/b][/quote]
So, O.G, with that being said, would a 24-36V street rider benifit from a 6Volt motor.... If I were to run 4 six volt motors on my setup, would 2 bays of 24V be reliable and quick?
Originally posted by vwlownslo+Oct 13 2003, 01:32 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (vwlownslo @ Oct 13 2003, 01:32 PM)</td></tr><tr><td id='QUOTE'>
So, O.G, with that being said, would a 24-36V street rider benifit from a 6Volt motor.... If I were to run 4 six volt motors on my setup, would 2 bays of 24V be reliable and quick?[/b][/quote]
YES, YOUR CAR WILL RAISE UP FASTER, BASICALLY, THE MOTOR WILL SPIN 2 TIMES AS FAST.
I can't fit to many batteries in my car, and want to run my four pumps, so MAYBE 6Volt motors is the answer, As I would have comparable lift running a 6V @ 24V to a 12V @ 48V correct?
yet I would have a bit more (pretty well double) the switch time by using the 6V motors.....
Would I burn out the 6Volt motors quick running them @ 24Volts?
1 - 13 of 13 Posts
