1 - 20 of 26 Posts
i'm planning an install. is 60 volts to the nose with a CCE Fatboy pump with #9 pump head too much ? should i back down to 48 and just rewire when i feel like playing a lil faster. i plan to have 3 1/2 ton springs
i put 96 v to the front on my caddie w/ a fat boy 4 ton springs , did great
just make sure you have a quick connect inside the car and enought solenoids to handle that kind of voltage , we ran 4 accurates and they r still doing fine
True-S Mike
i run 72 volts full time. have been for goin on 3 years.... only replaced a motor once in that time
Have 60 now......going to 72
WHATS THE BEST COMBO. AS FAR AS VOLTS. TO GEARS,,,,WOULD A GEAR 11 WORK BETTER THAN A GEAR 9 @ 84 VOLTS? OR SHOULD @ 11 NEED LIKE 96VTS. SINGLE PUMP.
LAYEDBACK
I have 84 volts going to the nose (single)with a #11 gear.It works well.I'll be switching it with a #9 soon to see if it does any better. :cool: :cool:
I started out with 0 knowledge about hydros and 72 Volts.
Here's what I learned in a nut shell TAP THE SWITCH!!!
even a light tap moves the car like a sonbitch. I got used to it pretty quickly after I blew a hose. :biggrin: After a few months of doing some reading on this site I actually realized that I was running at 72. The installer had told me it was 48.
I felt pretty pimp for being newbie and starting at 72 :cool:
LAYEDBACK
Originally posted by NEIGHBORHOOD LEGENDS@Aug 24 2005, 02:14 PM~3682968
WHAT TYPE OF CAR, AND HOW MANY INCHZ ARE U HITT'N RIGHT NOW?
64 Impala Not sure on the inches. :dunno:
Only pic I have of it.With a touch of the gas pedal. :biggrin:
Member # 1,077
i have a #11 with 48v single gate, its just not enough anymore.
G
youll defeintly be better off with that #9 on 84v
yah man but you know you need more volts :biggrin:
Member # 1,077
i want like 60v
Discussion Starter · #18 ·
the lower the # pump head the less voltage to use right? the bigger(#11 or #13) gotta use more voltage...and i remebmer back in he days of reading Lowrider all the talk was either #6 or #8 pumphead
I have two switches for the front of my monte. One running 60 volts for every day driving and one switch for hopping that runs off 96 volts. You could even run 72 volts for every day riding. Anything after 72 you will start burning up motors and noids.
Thats funny, my first time trying to hop i started off at 96 volts and burned a shitty solenoid up on the second hop, this next time i will start off at like 60 volts :uh:
1 - 20 of 26 Posts
