I have a 62 impala with airbags. I’m getting a vibration at highway speeds 60-65 mph mostly the whole car shakes , I already did the following repairs;
New tires balanced
New front end (tie rods, pitman arm, center link)
Drive shaft with new center support telescopic balanced , pinion angle checked
Tried different set of wheels (15” supremes) did the same vibration
Front alignment
What else should I check or replace?
New tires balanced
Front alignment
U might have a differential issue aka rear end axle. I would replace it with a Toyota Tacoma rear end
