1 - 3 of 3 Posts
Tail lights , turn signals work and reverse work but brake lights won’t work . Replaced the headlight switch , still nothing. I have power going and coming from the brake light switch
I got the wildstyle
Instragram: Kiloz_One
You need a voltage meter to test the wires in the trunk. Have someone hit the brake and see if the wires are getting power. If they are getting power in the wires its most likely a grounding issues, you can run a wire and ground all the lights to the trunk.
Also check to see if you taillight harness is plugged in or damaged.
1 - 3 of 3 Posts
