1 - 5 of 5 Posts
how many turns for a 63 with 14''s in the rear and what tonage. some recommended precuts but im not sure. coilover with 8 batteries 3 pumps
You can take a Pro Hopper 2.5 ton and cut it in half and it is the perfect length for what you want, if you use reverse deep cups the coil will have to be longer. Just weld some 3.5 round tubing to the donut and use that as your cup.
Face Puncher
I used 12" cylinders, reverse deep cups, and I got a pair of 2 tons from Showtime, cut 1 1/2 turns off each side, it lays out pretty low.
thanks for the info i think im going to order 2 tons monday and make the cuts. i got 14 " cylinders though, ill play with it. see whtat i can get.
Face Puncher
[snapback]3510205[/snapback]​
I think with 14's, it will still drop as low, just more of the casing will poke through the trunk
1 - 5 of 5 Posts
