1 - 2 of 2 Posts
I am taking the pump out and the 2 cylinders on my convertible top. Do I need to drain the hydralic fluid first. Also the 2 cylinders inside the car are leaking. What could be the cause. Thanks FAM
if the top is close their is going to b a little fulid in the lines if both cylinders are leaking more then likely the seals are bad and need 2 b replace
1 - 2 of 2 Posts
