1 - 14 of 14 Posts
im clueless why it bogs down when i step on the gas like it's getting to much air or something...my 64 has a 327 from a 68 camaro intake manifold heads are all original ...i have a edelbrock 1406 600 cfm electric choke carb on it with adapter plate,full length headers...any ideas why it would be doing this? anyone ever had this same problem?
i dont feel tardy
needs tuned
edelbrocks are bad for it thats why i prefer quadrajets
my cousin came by and tuned it one day,guess maybe he didn't tune it right
carburator
:yessad: :yessad: :yessad: :yessad:
i dont feel tardy
probably not edelbrocks are tricky
cool thanks least it's nothing major :cool: ...just have to find someone to tune it right
i dont feel tardy
drive it up here :cheesy:
Originally posted by Firefly@Jan 19 2010, 06:49 AM~16336557
Either that or your fuel pump is busted (or fuel filter clogged/line pinched somewhere)
X2 any trash in the filter?? Clogged, or collapsed lines from the gas tank!?? :cool:
[/b]
<!--QuoteBegin-81.7.TX.
@Jan 19 2010, 01:18 PM~16338875
i think the fuel pump might be old,fuel filter is new and has new lines and gas tank
First make sure the choke isn't closed all the time causing no air to be able to enter the carb. It may be hanging up on the air cleaner base or just adjusted wrong.
ALSO
Get it to idle at operating temp, set timing with advance disconnected and plugged to 8-10 BTDC, set idle to about 650 RPM in gear. Connect the vacuum advance.
This will give you a decent place to start
I would try adjusting your power piston.... that little arm on the front right side of the carb. It comes out the box in the middle hole, move it to the upper one, drive the car, if it didnt help or made it worse, move it to the lowest one, if that doesn't help, go back to the middle and check something else. I had this problem with my 1406 on my 283... the power piston was shootin in too much gas when I stepped on it so i had to adjust it to have less fuel shootin in :puffin:
The neoprene hose that connects the filler tube to the gas tank rots and is easily forgotten!! Replace that to reduce trash in the tank!! :cool:
1 - 14 of 14 Posts
