1 - 11 of 11 Posts
MY brake lights don't work , front lights and turn signals work , rear turn signals and reverse lights work . I already replaced the brake switch and checked the brake fuse . any help will be appriciated . thanks :confused:
The bulb socket that plugs into the tail light lens reflector has a metal clip on it that is supposed to make contact with the reflector. They often make poor contact which is the ground connection that 817.tx was referring to. The lack of ground can cause all manner of weird behavior on the tail lights.
check your turn sig switch and then take tester with a light on it ground one end and stick the other on each wire end at the plug in the trunk if they work there its in your wireing to the brake lights.
I had the same problem with the brake lights not working but I figured it out and also have some pix to show what the problem was but I don't know how to post the pix so if anyone is interested in the info I can send you the pix to post.
Brake light issue repair
Hi i have since fixed my brake light issue , the emergency brake cable was snapped and the switch was not closing causing the brake lights from turnig off . Check the emergency cable , emergecny bracket switch ,tail light contact to the bezel, and the brake pedal switch .
Your mom loves my
I have a 64 Impala and I'm not getting nothing...No brake lights,no tail lights,no blinkers,or plate light...Please help...lol
Check where the harness disconnects near the back seat. It may have come loose or is frayed. :nicoderm:
  • Like
Reactions: Rogerzz
1 - 11 of 11 Posts
