Originally posted by 94TC@Sep 10 2005, 07:50 PM~3789696
O.k. got it working but am having trouble with the amount of line I need to keep as slack. All I can do is get it lifted but not come back down. Kinda sucks but will be persistent. L8R
sounds like your making progress :biggrin:
on those little guys you have to make sure the ubar is not being pulled back
by the string your using. if it is it wont let it come down has to go straight up
and down. you can add a gide under the chassis for keeping it straight.
or if you use regular string.
it will bind on the motor shaft ,I only use fishing line 10 lbs.
and they work find also needs more power.. and also when you atach the string
to the motor try to put whatever your using to hold it as close the end
of the shaft of the motor as possible that keeps the string from locking
up on itself.
late.
