1 - 2 of 2 Posts
Bay Area freeway rider
i recently put a tilt in my 64 ss, after some research i find out there are differnt length lower shafts. i was wondering if anyone had used there old shaft and still made it work, like with something from flaming river. its a 3.5 inch gap. any info on the subject will be helpful thanks
Yes, I re-used the non-tilt shaft, which is longer, cut it then rewelded. It is hard riveted at the bottom. I just drilled out the rivets, then used 5/16" bolts and nylocks to bolt it back together. Don't forget the grounding strap. Pretty simple.
John
1 - 2 of 2 Posts
