As long as you have a slip yoke in the driveshaft, go and get a new tube put in... Any truck driveshaft/clutch shop should be able to do it and turn it around to you in one day. They can add a tube of any length.
Check spring shops too sometimes they do drive shafts.
It shouldn't be too expensive.
If you dont have the slip yoke, you'd be better off ordering a new back half from Island or Arizona Drivelines. or have the place put in a slip.
Lift the ass and measure, then drop it and measure, then you know your range.
Good Luck.. Don't worry about it. It's very typical to have Shaft problems.
