1 - 20 of 26 Posts
Brougham
my homboy just bought a 64 impala ss from arizona, and the rear cylinders are mounted on the lower traling arms???? now have never seen this done before, is there some reason this is done. will it hurt any thing moving them to the rearend ???? :ugh: some pics would help
On X frames the cylinders are mounted on the lower trailing insted of the axle...
here is my 61....
I've never seen nothing different on a x frame....
Originally posted by caddy4yaass@Jul 21 2005, 02:56 PM
the cylinders also dont have power balls :uh:
[snapback]3449685[/snapback]​
Hyme Joint ?
Originally posted by caddy4yaass@Jul 21 2005, 03:00 PM
nope  just a piece of square tubing welded to the traling arm.
[snapback]3449720[/snapback]​
Post a pic when you got...
the huy probably drilled the bottom of the cylinder...and ran a bolt thru the box tubing ...
thats prob why they are sitting f-uped. cut out the front section of the tubing so it wont bind up.
nice looking car, messed up cylinder mount, you need to jack that car up and check it out underneith. Is that cylinder even bolted on? It shouldn't be sitting at that angle at all.Why is there 2 different squares welded to the arm,looks like it should sit in the back ones?
The reason most people have them on the trailing arms is because thats where the factory springs sit on x-frames, so you got the spring perches up on the frame up there.You could move it to the axle houseing,but you'd have to fabricate a new spot for the springs to sit up top
[snapback]3456168[/snapback]​
^^^^ what he said. that bitch is not even bolted in... and I think from the looks of where the top of the cyl is positioned it should be in the back mount
1 - 20 of 26 Posts
