1 - 20 of 64 Posts
Originally posted by Switchblade@Aug 17 2006, 12:43 AM~5984265
Goodluck with it .. Comes with different sized cylinders and everything :thumbsup:
yup, you can either make the ass end up, nose up, raised up, lowered and a 3 wheel but i dont understand the instructions for the 3 wheel :angry: any help?
You have to cut the front suspention apart on both of them and glue it back together. I think thats right. Or you could just raise the front all the way up and lower just one side of the rear. ;)
Just lower the one rear, that's what the real ones do. Only cut the front lower a-arm peices for the side to side lay
I knew it was one or the other.
[/b]
<!--QuoteBegin-BigPoppa
@Aug 17 2006, 02:02 AM~5984675
i get it now but i dont get the part about cuting the fron a arm for a side to side lay?
Thats when you have to cut it in half and glue two of them together. You'll have one side low and the other raised. Then in the back put one side big cylinders and the other side short.
Oh hey .. An early tip
DONT forget to get hoppin hydros or pegasus rims .. The ones that come with it JUST DONT CUT IT :thumbsup: And they're worth the money if you want something to look at and be extra proud of its sexyness ;)
www.scalelows.com if your local stores dont carry them
Discussion Starter · #13 ·
so if the back left side of the car is raised which side in the front do i want lower or higher?
Are you talking about S2S or 3 wheel? On side to side both of one side should be raised. If your talking about 3 wheels, like we said just put the all up front on it with one side of the back dropped the other side of the back raised.
Discussion Starter · #17 ·
mmkay
Discussion Starter · #19 ·
I painted the body and the frame from the left over paint i had from my bike, there is flake in it but you can't see it because this camera is shit and my flash doesnt work :angry:
1 - 20 of 64 Posts
