I want to install this gauge cluster in my 78 cutty..
this one has two places where wires hookup .. and the original one only has 1
i tried to install it but.. the only things that i can get to work is the speedometer and the signals.. my gas gauge didn't work in the orignal one either
so is it possible to do the swap? i still got the original one laying around.. and pretty soon ima take the dash out again for like the 50th time and don't know if i should stick to the original one or not..
i ended up installing the 1 i wanted... old topic.. but heres the pixs
your cutlass is missing volts, water and oil wires you need to hit the junkyard and buy the temp censer, water cencer, volt wiring. the fuel should read you need a wiring diagram book 85 cutlass 4dr cutlass have that same guage set up
[/b]
thanks man!! thats what i wanted to know..
<!--QuoteBegin-KAKALAK
@Aug 1 2010, 10:41 AM~18198888
good time to wrap the dash while its out :cheesy:
i already dyed it
