80`s big body caddy
1437 Views 21 Replies 17 Participants Last post by  monsterpuff
G
i welded my chains on the out side of the rear of the c-channel in the center then i ran the chain down to the chain mount on the axle i adjusted it about 10 times and i can`t get the car to 3-wheel over 10inchs i have 16`s in the rear and prohopper adjustable uppers
any help?
1 - 20 of 22 Posts
u sure ur chains are long enuf they should be about 14 inches with 16 in strokes
who needs chains :dunno:
how many turns r in ur coils? it may not be sittin low enough...
Is the car bridged , if it is maybe the hole ain't big enough to let it roll down the cyl. I had that happen when i did mine, second you don't need chains on a caddy you need weight!!!!!!!
Post pics of the axel and bridge setup
i got a 83 sedan, 8 batts, 4 pumps, 16s no chains no bridge, it 3s all day both sides, 4 switchs
Sounds right , Im running 12 inches with 14 In cylinders on my Box Caprice wagon. :thumbsup: But I can pause with out chains also, only reson im running chains is cause I ripped my upper trailing arms off twice.
G
ok i got this thing figured out i had the chains in the right spot the problem was i was using the factory front springs in the rear i tossed them and added a set of 2 ton cut short and the bitch pause`s like a wet dream i will post pic on this topic and my other topic later tomarrow tonight :thumbsup:
X 100 ;)
Originally posted by hosscutlass@Sep 16 2006, 07:55 AM~6185771
http://www.youtube.com/watch?v=ZthhXGIlAho
Nice, but why does the front seem to come up so slow? I thought you had it coming up fast enough to hop.
I personally like to have the back come down slow though.
G
i wired all 3 pumps at 36v for a min til i get all my batterys and yea i need to slow the rear dump a bit
clean
just wondering if your frame is wraped or anything reinforced. looks good
He took the body off & reinforced it , here yah go check it out.
http://www.layitlow.com/forums/index.php?showtopic=248725
1 - 20 of 22 Posts
