1 - 12 of 12 Posts
How many shims should i use? im using two and the starter is getting stuck in the flywheel? New flywheel also :dunno:
you need to check the pinion to ring gear clearance.. should be .010-.020
Originally posted by pink63impala@Sep 8 2006, 10:12 PM~6134181
try none
or, measure the ring to pinion clearance and do it right.... ;)
none may work..but measure to be sure
Originally posted by RRG@Sep 13 2006, 07:17 PM~6166235
ill try them is it common to have a bunch of shims in this motor?
my old engine (267) had 1, my 350 doesnt use any
i it's sticking use more if it drops out use less ...
if it turns over real slow you got too much advance on your initial timing :biggrin:
did you make sure you got the same tooth on the flex plate for the starter end gear?
youve been paying attention to the eazy e topics :cool:
ya a lot of old timers keep telling me they never used shims. I bet its that autozone starter :machinegun:
different engines need different things
i got it fixed it was the wrong starter autozone told me it was the right one :angry: Thanks for the help
1 - 12 of 12 Posts
